Michael_Z32
Hi SF, I have a 2019 AWD 3.3TT, it’s got 1100 miles on it and I installed JB4 @ around 250 miles. Regapped my OEM plugs right after install and I was running map 0 until around 750 miles. After the break in period, I enabled the JB4 on map 1 and ran for a bit, then did map 3 and ran E30 later on. I ran a Mercedes E550 using map 5 (I know I know I shouldn’t have), and while I pulled off on him as if he was parked, after the race I noticed my turbo was whining a bit— not normal whistle, a high pitch whine. I turned it down to map 1 and I’m running the JB4 extremely conservatively now. I spoke to my tuner and he said that’s a symptom of overboosting (important to mention I had this issue on my Optima 2.0T with no tune) he said I’d need bigger turbos if I wanted to keep making power. I don’t have intakes or DP. I’m under warrantee so if the turbo(s) go out I don’t care to go back in to service to have them replaced. It is also worth mentioning that on the regapped plugs I was experiencing spark blowout on exactly 70mph and 90mph.
My question is this:
if I’m running map3, what mods should I have, and the same for map5. I’m okay with intakes, plugs, etc. just can’t do DP
I can’t have a loud exhaust due to the fact that I share this car with someone. However intake noise is fine. also, are intakes necessary for these maps or is it just a plus and added power? Thank you in advance.
