Slight creek noise towards back of car when i slightly turn the steering wheel left
Amayeobu
Hi has anyone had this problem where you hear a slight creek when you turn your steering wheel.
I have not. But I have read of steering wheel extraneous noises, variously described as creaks, scratching or crackling, even grinding. Loud and soft. This is the first time I've heard someone describe a noise in the rear when associating it with the steering wheel, though. Hmm.:unsure:
Tons of squeaks, rattles, and weird sounds from the trunk... not from the steering wheel... yet... ;)
yeah inanely hear it when I slightly turn the steering wheel while driving. do you think this is warranty covered
Bring it to the dealership. Should be covered under warranty.
All Stingers are still young enough to be under warranty right?!?!?
If you take a techie for a drive and they hear what you hear, they will look into the cause. Good luck! :thumbup:
May i suggest greasing the armpits a little. Lol
Sure its from the back? Mine does it a bit after replacing my front pads, but from the front. Could also be the weight of the car shifting a bit, my one rear spring was creaking a touch after swapping my lowering springs out for the stock ones. Take it to the dealer, that's a warranty issue for sure.
