Seat Options
Southeast
Does anyone know or have an idea on if G70 seats would fit in our car? The rears would probably be the biggest challenge but I wonder if you could just replace the covers to make it match?
Why you ask, well I have a base GT and it would be nice to get ventilated seats. I assume the seat track would be fine. But I don’t know about the connectors for power seats, heat, airbag, everything.
I’d also look for swapping GT1/2 seats or just the blower.
If anyone with ventilated seats removes a seat for track, cleaning, swapping seats, whatever. Can you take a picture of the bottom? If I can get the cluster swap figured out ventilated seats is my next project for my base GT. I’d like to get a pic of the blower and the connections.
Please refrain from why not just get a GT1/2 or it will cost too much to do it. Maybe it will and maybe I should have. I’m just more concerned with the technical aspect on if these things can be done.
Probably not as the floor pan is different and cars much smaller n dimensions
That’s a good point. I might just consider a Stinger seat swap with a 19 GT1. Reason being is the 19 GT1 seems to be the same seat as a GT except with cooling. GT2 has memory seats and more adjustments. So I would assume the GT1 has the greatest likelyhood of being a plug and play.
How would you get the controls for it though wouldn’t you have to run new wires to the control center for the seats where the heated seats are located ?
