Welcome. Moving this topic to the technology forum.where does it go?
Also I just updated my map software recently, I was running the early 2019 software lol. Bought a sandisk 32gb class 10, Loaded the software onto new SD card, put it in the car (like post above points out) and drove around for 20 minutes. All good now!where does it go?
I did it in hopes my Apple car play would stop disconnecting randomly...it seems to be working better. Might as well, SD cards are only $15.Are there really any improvements? I never use their NAV and choose to run Waze. Do the updates change the user interface at all? My car is a MY 18 built in Nov and purchased new by me in Oct 18. I doubt the dealership updated before selling To me and I’ve never updated it either
Downloaded update onto Sd card went out to car. Went through update procedure and when I got update it says to install the card. Won’t recognize the card. It’s a brand new Sandisk series 10 extreme plus 90mb/s? What am I doing wrong
did you drag and drop the update or use the installer from the site?Downloaded update onto Sd card went out to car. Went through update procedure and when I got update it says to install the card. Won’t recognize the card. It’s a brand new Sandisk series 10 extreme plus 90mb/s? What am I doing wrong
Simply copied from hard drive to SD cardid you drag and drop the update or use the installer from the site?
I had to do the same it would not work as a copy from the hd.mine didnt work that method. i had to use the installed and when it asked where i wanted to put the file i selected the sd card
Strange...I just used the Kia installer, loaded it onto the external device (SD card) and it was done after 10-15mins. Then inserted it into car, went through all the steps and once it disables all radio functions I drove around making a ruckus with my exhaust.Downloaded update onto Sd card went out to car. Went through update procedure and when I got update it says to install the card. Won’t recognize the card. It’s a brand new Sandisk series 10 extreme plus 90mb/s? What am I doing wrong
Just tried again. Says card has 29.7 mb and when I hit start it says not enough space on disk and the file is only 26mb. I even reformatted the card and used the navigation updater, So annoying.
Navigation updater will not let me choose the card as my location says has to be a hdd. Why do I feel so stupid?
