Scan Gauge for Stingers?
FriboRage
Hey everyone!
In my old car I had an obdII scan gauge - Aeroforce Interceptor
It was a really nice little thing that displayed a ton of PCM data PIDs 2 at a time, hooked right up to OBD port.
I’m looking to see if anyone has any recommendations for something similar, maybe a little more up to date, for use in your Stinger.
I’ve looked around a bit but if there’s one that’s popular in the community, I’m having trouble finding word of it.
Thanks!
had this in my last car, now in my Stinger ... changed to KIA logo, of course.
Lufi XF Revolution gauge
That looks nice, and pretty much what I’m looking for, thanks!
Reading into it, there are notes that say boost is both supported and not supported. Does boost work on our cars? That’s like 75% of the reason I want it.
Is it just suction mounted in the same(ish) spot on the stinger?
yes, the pic actually shows the boost gauge (-20 vacuum to +30 psi) ... also why i wanted it. also nice for battery voltage, air fuel ratio, etc.
some functions dont work with some cars - unfortunately trans and oil temp, current gear, and others dont work, but theres plenty parameters that do, and you can choose which ones you want to display.
not suction mounted - has a metal base with tabs to adjust for irregular surfaces, and held on with double sided tape. plugs in to the OBDII port.
Looks cool! I just use my JB4 and phone.
I know this is kind of an old thread, but I finally got around to this gauge… anyone running an obd gauge, where did you run the wire down into the dash to reach the port?
Hey everyone!
Thanks!
I really like the Aeroforce, have that in the Lightning. I probably shoulda bought 2 though.
