AV8R
5000 Posts Club!
- Dec 13, 2017
- Location
- Perth, Western Australia
If any of you are using an ultra fit USB to play music from watch out. Due to the high read write speeds it heats up and when it gets too hot the left channel in the sound system drops out. I only had this happen today and did some research. Apparently it’s a flaw in the USB and avoid 3.0 USB s and stick with 2.0 as they don’t get as hot.
I tested the radio and sound system is fine and later did a check on a cool USB works ok too so it has to be a heat problem.
They did say a sandisk Cruzer fit is better as it has 2.0 speeds whilst still being small.
