StingertimeNC
1000 Posts Club!
Ok gang, looking for some sound advice. I've been thinking about what tire size to move up to, but I don't want to get so wide that I end up with worse acceleration grip. In general, my understanding is wider tires help with lateral grip, but may not be so helpful with acceleration and braking as the front to back contact patch is shorter. I currently have stock Pilot PS4 19" tires, but on my new 8.5 wide front and 9.5 wide rear tires. so 225x40 19" up front and 255x35 19" rear. Vossen, the wheel manufacturer suggested that I can stay with stock tires, which I did as they only had a few k miles on them, or go up to a max of 245's in the front and 275's in the rear. I'm RWD so traction is somewhat of an issue at launch. I currently have the JB4, running map 2, and will be adding meth soon.
I could also go with 235's in the front and 265's in the rear. I'm not in love with the stretch look, although I can live with it as is. So, go up to the largest size tire I can, or split the difference and go up only one size. pick up a little lateral grip, but maybe lose a bit of acceleration grip in the process. Or, will the two up-size options not even really have much of an effect either way?
