Rims and tires
aDumpsterJedi
In the market for new rims and tires, let me see what everyone's running and let me know how they work for you
I saw that and it's just rims, im looking for tires as well and how people like the set up and what they dont like about them. Thanks
19x9.5 +22 with 245/40 all around.
They are some ESR copy of Work wheels
Dunlop Direzza Zeta3
A little poke but no spacers and good fitment!IMG_20250414_081833153_HDR.webp
Wow @DoctorStiches those look great; I would've expected the tires to look stretched and the wheel rims to poke (by my math you're doing the equivalent of adding a 31mm front & 37mm rear spacer), but maybe the stretch+poke cancel out a bit.
Any pictures from more down the side?
I don't have any on me that are good side parallel shots but here is an idea of how far the bottom of the rear kicks out and the 'poke' from the passenger door looking back. I'll take a couple good ones when I'm done at work
I'm a fitment nut. The same way some people can understand quantum mechanics I understand stretch poke and offset
Here are some better photos of the stretch/fit
Basically the tread itself is under the fender but the sidewall is exposed!IMG_20250604_171554686_HDR.webpIMG_20250604_171547847_HDR.webp
No problem with rubbing, super clean setup
At this height it does rub over hard bumps in sport mode, I've got to turn up the stiffness to a minimum of 60!% on the Mando to stop that. When stiff no rubs.
Curious, are you on lowering springs? How much negative camber are you running?
