Replaced spark plugs
miche25
About replacing the Stinger Gt spark plugs, I hesitate to do between with or without removing the intake,
I would like to have your opinion which is easier?
Removing intake manifold will also allow you to check and clean the intake valves if necessary. It took me about 1hour when i first did it. But once you know how to do it, it's 10min job.
I have a good feeling for the method (remove intake)
Question: Do I need new gaskets before replacing the intake.
I reused them, without any problems.
