Rear Sway Bar DIY
f155mph
Hello,
Have anyone done a rear sway bar at home with jack stands? The front looks easy enough to do, but the rear looks a lot harder. Is it possible to feed the bar from one side to the other? Seems like there are lots of stuff in the way.
Thanks!
It doesn't come with one?
Do you already have the eibach rear bar? Can't seem to find it in stock
Hello,
Thanks!
Yes, the rear bar is removed and installed from the side. Wheels off, unbolt end links, unbolt brackets, slide out, reverse for install.
The Eibach rear comes with detailed instructions.
