Rear stinger badge
Schroedes
For you guys that have the stinger logo on the rear. I have a 21 so mine came that way but I really wanna make the logo black to go with the rest of the car.. what would be the easiest route. Remove the stock and paint it? Buy a black logo? Are there holes with the rear stinger logo? Easier to do than the front badge removal?? Any help in advance is appreciated.. thanks
What was your removal process? I put a small divet on the front doing the front badge. Don't wanna have another in the rear
Doing a search on this site will lead you to posts with detailed instructions on how to change out your rear emblem. Here is the TLDR version:
1. Use thin dental floss (or fishing line) to remove the existing Stinger emblem
a. Do the work on a warm day - that makes the adhesive softer and easier to slice through
b. Use the dental floss to gently saw back and forth between the badge and the liftgate
c. Take your time and be careful to avoid damaging the paint
2. Remove any residual adhesive on the paint (e.g., with Goo Gone) and then clean the paint surface to prepare it for the new emblem
3. Carefully apply the new emblem
is selling a glossy black emblem for $13.99:
If you want the actual OEM emblem hydro-printed and then sprayed with a high quality UV resistant automotive clear coat, you can get it here:
The one mentioned in the post above isn't an OEM piece, doesn't use 3M tape and most likely doesn't have a finish as nice as what we offer in the forum store.
