Rattling after eibach springs installation ? Help
Hey y’all I just got the eibach pro lowering kit installed on my stinger by a local shop. The kit had the springs sways and white line endlinks. It’s been about a week and I notice a rattling / light clanking come from the driver side/ passenger size front. It wasn’t there before and it seems to happen even without hitting bumps. Do you guys know if this is normal?
Should I take it back for them to look at and is it possible that something is loose?
Do y’all think adjusting the settings could help?
Any info I can gather will help. It wasn’t cheap so if they could’ve done something wrong/better. I want to hold them accountable.
I have the sways, but no springs, and have been silent from day one.... I would say something isn't right and it isn't a setting change
Check the sway bar links first. The front brackets are really easy to get to, those would be my next step.
I just bought a Stinger GT2 that came with the eibach pro-kit springs/sway bars and whenever I am turning the wheel to either side under 10mph (perfect example is parallel parking) I hear clicking. Brought it to a couple shops and they say everything is installed right and the noise is just from the car being lowered. Curious if you figure anything out as my sway bars/sway bar links weren't an issue.
Make sure the Endlink connections are torqued up correctly, if they are slighty loose that can ”click”.8945DEAE-5D12-4188-AB9D-824E4C06BE47.png
Almost 100% your swaybar endlink needs to be tightened down, its a common thing that would make the exact noise youre experiencing.
Got it thank you man, I’ll be going to the shop that installed them on Thursday for them to take a look
I’m going to take it in on Thursday to tighten the endlinks and see what happens
