^well said. I agree service techs are not going to flag your car as modded, just because you've got
aftermarket plugs gapped tighter than stock. That's if they bother to check. Unlikely, if there is no reason to.
FWIW, I've got JB4 in all our Stingers and
G70, running NGK ILKRQ7G, which are pregapped at 0.028". For the track, we run map 1 or 2, but for everyday driving, map0 only, which are most of the miles put on our cars. For me personally, I'm much more likely to hypermile on everyday commuting, so the ECU is constantly leaning the mixture as much as possible, no doubt stratifying the intake charge often, per the way I drive. I have yet to notice the slightest bit of drivability problem. That said, I live in the warn south, so very little experience with extreme cold conditions, where gasoline would be more hesitant to flash into gaseous phase and more likely to stay only finely atomized droplets. That might possible make the intake charge more difficult to ignite.
Ans, yes, bad gas, or stale gas, that has lost the more volatile fractions would also present a ignitability problem. As long as you are driving your car frequently and you buy your gas from a busy corner gas station, that should not be an issue.
