Painting chrome emblems
Gus Quintero
trying to paint the “stinger” emblem in gloss black from the stock chrome. Any help? Thanks in advance.
Its virtually impossible to make it adhere long term ( i'm the test bot on this one ) , the important issue is to sand as much of the sheen off as you can , this is way more important than primer or xtra coats , spend as much time as you can stand with a 500grit or higher wet sand .............2 coats of primer and 3-4 coats of top coat and at least 2 coats of clear coat ......................even after all this you might find chips after a few washings ( NEVER take it to a auto wash ) Good luck ( Plasti Dip with glossifier is more durable )
You can check out this thread " Glossy Black Stinger Lettering " by Ivansito, lots of feedback and info you might find useful.
You could just use a "Marks A Lot" and apply often. :P
