So I was rear ended 2 months ago. Only cosmetic damage. Fixed the bumper, etc and all of a sudden I'm getting heavy vibrations under braking of 60km/hr +. Got it checked out and dealer said rear rotors are warped and rear pads are nearly done. Do you guys think having the car sit for a month would cause pad deposit? Car wasn't vibrating at all before. Or is just a coincidence?
Wagner rotors and pads
26,000 km on them
rear pads 5 mm left
rear rotor 0.0021 inchs run out
fronts still good 7mm on pads and run out within tolerance
did some heavy braking at 80/90 km + and vibrations are significantly less but still there
OEM pad and rotors lasted me 50,000 km. Daily driver lots of stop and go traffic.
26,000 km on them
rear pads 5 mm left
