P25A0 code?
SneakerB
Anybody ever had this code and found a fix for it? Checked ewg wires and they seem fine car is super sluggish and will only get up to 16 psi of boost!
What if you return it to stock?
Well looks like it was from my lozic ecu tune after numerous emails back and fourth from Terry at bms he had me do a few things then told me to try and switch back to stock ecu. This eliminated all codes and car ran perfect again even threw it in map 3 and did a couple pulls and still no codes after restarting. another reason why i buy bms everything if i can!!! Terrys customer service is as good as it gets!!!!!! also had code p2562 pop up with PA0AA & PAAAA a couple times and then go away
Glad you got it figured out. Yes BMS and Terry in particular go above.
Terry helped me with my WMI issues after I installed it.
Great customer service.
Older post but I just had this come up yesterday and car lost all power.. emailed Terry to see what he thought.. then found this string. I may have to change my EWG Bias and FF numbers maybe.. but will see what Terry says first.. ‍♂️
