I'm having a similar issue:
- In Map 2 & 1 the car shudders and then goes into limp mode after throwing a P0049 (overboost) code at any kind of heavy throttle
- App will intermittently not be able to create logs
- App Display sometimes gets stuck. All data gauges (RPM, Ign 1, AFR, IAT, Gear, Map) freeze at a certain point and I have to restart the app to unfreeze them.
History:
- Bought a 2020 Stinger in September 2020
- Installed JB4 including fuel wires and BMS intakes in March 2021
- Worked fine since November 2021
- Have taken JB4 and intakes off and reinstalled a few times since March when taking it in for service at Kia
Only
mods on the car:
- JB4, including fuel wires and bluetooth connector
- BMS intakes
- Denso plugs, gapped at 0.022"
- BMS oil catch can (although I removed this a couple weeks ago)
- Mando ECS10 suspension module
Any help would be appreciated!
