3.3TT Only Boost Showing in Software
TexasGenesis
2019 G70
Just installed JB4 with fuel wires. Had no connection so messed with the db9 connector for the Connect Kit until I could connect. But now I only get boost info on the gauges screen on software. Not sure what to do now. Anybody have the pin out for the db9 connector for the Connect Kit showing what info comes in on which pin? Any assist appreciated.
Sounds like an issue with the OBDII cable
Thanks. I'll check it out when it's not 99 degrees in the garage like it is now. Is there any way to send you a personal note/email?
2019 G70
Did you ever figure this out? Mine is doing the same thing after installation.
