3.3TT Oil leak. Help!
Buklau
Toronto, Ontario
So I went underneath my car to do an oil change and I saw this part covered in oil. Does anyone know what this part is and why it’s covered in oil? Where could the leak be?
Any feedback and advise would be greatly appreciated. Thank you!
130,000km 2019 GT2(Limited)
It's a power steering motor. But it's not what's leaking. And by looking at your under panel seems to be a big leak. Check oil filter housing. It sits right above that motor.
So I checked above and I noticed this, which is above that motor. Could it be this?
I’ve also lost this much oil parking for 12 hours.
It's a gusher!!! Better get it look at asap before bigger damage occurs.
Clean that area real good and let it sit. If it's leaking that much, it wont take long to see where exactly it's leaking from. But it looks like it's coming from the area where filter housing bolts to the block. So, failed seals maybe, or cracked housing? Oh, and definitely keep toping off the oil!
Did you discover where the oil leak was coming from?
