OEM Endlink length
ht_addict
Hamilton, Ontario
Just wondering if anyone has a set of front and rear Endlinks. If so could you measure the length of them and let me know. I had mine replaced with SuperPro but unfortuntely I have to replace the rear (torn boot) and front (leaking grease) and want to start with proper length. Dont have my originals.1000001127.webp1000001124.webp
Edit:
I believe the rear link length is 115mm & fronts are 295mm.
I believe the front link length is 115mm & rears are 295mm.
If those are correct lengths, they must be transposed front vs rear. Front are longer than rear.
Yes sorry my mistake, I have edited & corrected it.
Man Im telling you these aftermarket adjustable endlinks are junk, all I hear is problems from people running them.
I’ve had Whiteline HD Endlinks fitted by a suspension shop since early 2019 & no issues at all.
Edit:
Is that the Length measured from the center of one ball joint stud to the center of the other?
Yes, that’s how I would interpret it.
FYI here are the torque settings for the links.
