Welcome aboard! And thank you for signing up. You found the best place to do your research! What might the Stinger be replacing?Hey all, I just completed a major life goal and will need new transportation. I'm waffling back and forth between an alfa giulia, GT1, or a used audi a5. Naturally, that brought me here.
Hah, well those three are kind of what I'm after. ... Well that and 4 doors. I don't care if it turns heads but kind of fast, at least a little refined, and dependable.
No test drives yet, getting finances and everything else set up first. I live in Austin TX though so all three of those are readily available. Looking to buy within the next few months.
Ride will be identical. Ride is pretty much identical across all the trims. That isn't where the differences occur. If you want the 3.3TT you are going to have to get a GT if you don't want a sunroof. I wasn't aware of a difference in NAV between the GT and GT1/2. All Stingers have UVO, Apple CarPlay and Android Auto. In the higher trims of both Stinger and GT you have an 8" touch screen instead of a 7" (referring to outside dimensions, I presume, since my GT1's actual screen is 7", the frame is tapered but is c. 8").There is a Genesis store close to me as well so I intend to check out the g70. This is probably not the right place but I'm trying to decide between the GT and GT1. I really don't want a sunroof since I'm here in Texas. I'm worried about the lack of Nav vs Android Auto and the ride quality of the GT VS GT1. Any suggestions?
