Welcome aboard! And thank you for signing up. I’m glad you found us!Disconnected battery and closed hatch. Google search "how to get in locked Stinger" and here I am... thank you by the way.
Worked out pretty good. From what I can tell there is an answer for anything Stinger related on here.
ha. I was just reading this post and imagined myself standing in front of YOUR stinger locked out and the battery inadvertently disconnected for one reason or another... this maybe useful in the future lolSo what was the answer you found that worked for you?
Good to have it posted here as well for any other future searches.![]()
Pull the physical key out of the fob, little button near bottom releases the key. The right side of the drivers door handle is a plastic cap. With the key, from the underside you can gently pry off the cap, carefully! That exposes the key hole.
ETA
What Wilzer said. For the trunk, I think you have to climb into the hatch via the back seat with the seats folded down. The glowing emergency release should pop the hatch but I’m not sure on that.
Also, not the Stinger but the same procedure. We all need to practice this, no?
