3.3TT New Log
These aren't useful. They don't show the car under any boost.
What you want to do is set the jb4 app settings to only log on boost, then do like a 20-80MPH WOT run (safely on a flat straight street)
To change the log settings, in the jb4 app, on the bottom right click on Settings -> "JB4 Tuning/AppConfigs" -> "AppSettings" -> "Logging Settings".
Change "WOT Logging Timeout (Seconds" to 10.
Change "WOT Start Threshold (Pedal)" to 80%
"Retain Log Grouping Setting" to On
Also, your jb4 FW is 24, the latest stable is 28, I suggest upgrading it.
Once you get new logs, post them here.
Thank you for your response. Will try to get it done today.
Good morning all. Could I get some feedback on these logs. Have JB4 Map 1,BMS intakes, Xforce exhaust and mishi intercooler. 94 octane in the tank. Thanks.
Go WOT from 30 ish to 90 ish and repost. What you posted is useless. Be safe!!
Got another one in today. This is map 1 with 91 octane. Thanks for all the help.
Looks good. Go to settings and set your JB4 to automatically start logging when you hit 80% throttle. What other fuel do you have access to? Not sure if you want to run map2 on 91.
Thanks cncBilly. That log was on map 1 with costco 91 octane. Have access to Petro Canada 94 that I run sometimes on map 2. I do have options set for 80% WOT autolog. Happy things look good. Will try a few more logs when I fill up with 94 just to see. I am having issues with opening .csv files even though I have excel and/or open office. Will keep trying to figure it out. I have the ewg wires but don't have them hooked up yet. Will they make much difference?
EWG are more so for cars with cat removal ie. primaries and secondaries. I have ARK secondaries so I use them to prevent over boost.
What setting did you use to prevent overboost, did you drop the FF below 50?
It’s been quite awhile can’t remember. I did what BMS recommended.
