Need Help
mackker
Hello there, I am wondering if anyone knows have to access the harness under and behind glove box? I hate the Kia Connect App and remote start so I decided to buy the Accessorides starter. When I removed the panel under glove box, the harness I have is completely blocked by a metal bracket and I don't know how to remove. I see two bolts and Ive removed the nuts from them but not sure if this will do it or not and if those bolts hold the whole harness in place. I have attached a couple pics of the area. Any help is appreciated.
Thanks
Bryan
On your first pic it looks like a ”spring” type clip on the top of the cover, check if it has one on the bottom & maybe they lift to remove the cover.
Thanks but I think its a solid bracket riveted to the canbus. I could probably cut it but it's risky with all the wire and using a Dremel or something
"Cut it"??!! :eek: Talk to @General_Vodka he knows everything about that area (including that the TPMS sending unit connections are there, he told me that much).
^^^No, no, and no. No cutting!
No it's not. I wonder if there is a Canadian version of this guide as the bracket is only for Canadian market
What year is yours?
Mine is 2018, I will look closer next time I am in thete.
Mine is 2020. Ok thanks.
There is literally no trace of info on this
