Need help with OEM part number - BMS 0 Maintenance Oil Catch Can/ Rear OEM Intake Tube?
DustinCheeks
So when installing the OCC you have to connect the catch can to the longer OEM intake tube where the oil gravity drips back into the crank case. Does anyone have any idea what that longer OEM tube is called or have any idea the specific part number? To be more specific i am referring to the longer tube on the back side of the OCC with the insulated foam around it. I will try to include a photo.
I accidentally cut too far beyond the manufactured neck of the tube. I still got it to work and was able to sneak the OCC nipple into the tube but i would like to replace it anyway. I tried searching the OEM parts lists but cannot seem to locate that exact tube.
Below is an image that one of our friends on here sent me which shows the specific tube clearly. I circled it for better reference. Really hoping someone can help me out.
EDIT, that was for 2.0L. Ill try and find it real quick.
Thank you!! I've been looking non stop and i still can't find it.
Cut from the rear instead.
267203L100
