3.3TT Need Help With New Wheel Specs, Please
Metalmania82
Reading, PA
Hi all. I'm getting ready to get the Stinger back out of winter hibernation and I'm looking to replace the factory wheels with something wider from the aftermarket. I have a wheel picked out that I like but I would appreciate help determining if they would fit, as well as what tire size would be recommended.
If I have my info correct, my factory wheel/tire info is:
18"x8 at all four corners with 225/45-18 rubbers (AWD if it matters)
Offset is +40?? Bolt pattern 5x114.3 Hub 67.1
The wheels I would like to upgrade to would be:
19"x9 at all four corners
+30 offset, correct bolt pattern, and assume the hub size is correct since I entered the vehicle information into the wheel manufacture's website and it spit all this info back out.
Questions:
1) Will this wheel size fit correctly/safely?
2) Assuming the answer to the first question is yes, what would be the recommended or best tire size?
Thanks in advance to any and all input!
