Nav question - view turn by turn, detailed guidance
JSolo
2500 Posts Club!
People's Republic Of IL
Detailed guidance is enabled in settings.
Option 13, accord to the nav manual (MY22) is to show/hide the detailed guidance.
What's odd, is that button isn't always present when navigating to a destination. Sometimes it's there, sometimes not. Pressing on the streetname to the left (of 13) does nothing. Pressing #12 brings up the option to reroute. Is there such a thing as turn by turn directions with this gps?
I think if you tap 7 or 8 it drops down and gives you the details of the route.
Negative. That was my intuition too. I got nothing when tapping those.
I think I found a bug. It seems when that option isn't there (although enabled), panning the map then hitting the recenter button - near top left, next to home button will make it reappear.
I should see if changing to other screens does the same, maybe hit nav then map again.
I did some more testing today (only drive the car once or twice a week).
So when that button is missing (#13 from post #1), so is the button to cancel the route (#11, bottom left after the april 2021 update). Panning the map and recentering is one way to get it back.
I hinted in post #4 about pressing NAV then MAP. Apparently that works too. I have a ticket opened with mapnsoft, # 33753:1369581.
If this issue bothers you too, you can write to Oliver at info@mapnsoft.com and reference the above # and your concern. It bothers me to some extent but not the end of the world.
In my email interaction with "Oliver", I provided screen shots of software versions, a brief video showing the missing buttons. He now wants me to record a video while driving. This is too much. I replied someone from engineering needs to get of their behind and go drive a car themselves. The issue should be reproducible.
On that note, are others seeing similar behavior with the same car?
22 stinger gt-line awd with april 2021 update installed.
