Stinger 56721
- Jul 16, 2020
what out come of hp will i expect. ?, i dont know what the hp is in the 2018 gt2
Getting plugs and intake and JB4 with the fuelI'm assuming this is the 3.3tt? This is highly dependent on what sort of fuel you have available. I have intakes, Borla exhaust, and I run E30 mix. I run map 4 and I am probably pushing well over 400hp to the wheels and probably 450ft lb of torque. Do you have any other mods? Also make sure you get new spark plugs and gap them properly. You could gap the ones already in the engine but it's preferable to get new ones in there since you need to pull them anyways. You will definitely feel the difference. Good luck!
Sorry, E30 is the mix of your fuel available with E85. For me I mix 4ish gallons of E85 and then fill the rest with 93. It is roughly E30 mix.What is E 30 FUEL. I have not heard of that, we have E85
