Stinger-Performance
I was merging into traffic yesterday and the car started misfiring. I got off the throttle and tried to just cruise and it was still misfiring. I pulled over, turned the ignition off, back on, and the problem went away so I drove easy (tried to keep it at low boost) the rest of the way to my destination and back home. I then tried a hard acceleration near home and logged the behavior (attached). I noticed AFR shows full lean at idle/cruise after it starts misfiring which doesn't tell me much other than confirming it's misfiring (incomplete combustion = high o2 reading).
The car's ran perfect with the JB4 for about 25k miles and I've changed nothing in that time so for this to show up out of the blue without any hint of misfire before is a bit odd. I'm familiar with misfires as I've owned a ton of turbo cars but I've never had one that doesn't clear up until turning it off/back on, and they typically only happen in boost, not under all conditions, so I'm a little confused by what could be happening.
Can someone look at this log file and see if anything in particular looks out of line? Thanks!
