Map reviews and boost limit
Buzz0929
2019 stinger gts awd 3.3tt
Jb4, fuel wires, hks, borla, k&n typhoon, tial bov, and BMS wmi.
I’m hitting a limiter in map 3 and map7. Also map 7 wmi shows 100 flow all the time. Attached are logs of a quick run. Boost is up to 25 and cuts out when this is hit. Any help appreciated.
Did you have Terry check your logs ? your fuel trim is very high for running wmi , and on your map 7 logs showing 0 target for boost.
Terry checked logs and corrected the overboost. As for the wmi he feels that the blue wire may not be right so on my next day off I’m going to tear into it
I have wmi also and run 22--23 lbs of boost at same or lower fuel trim level.
Curious if you guys are having any issues now with over boost or if you're just running like that. I've had the wmi on mine now for 6 months but just got it tuned. Unfortunately the tuner was not any good for jb4 so I've since had to make adjustments one of them being the high 25 to 27 lbs of boost.
