Well, I highly encourage those cables!I’m going to do a log after work on map 4. I wonder if I install my ewg wires it would help getting to the right amount of boost but thanks for the reply brother I appreciate it
No where near as good as AWDGT2 at reading these (getting a lot better though) but that timing is some of the better I have seen in a while especially at that map. That is some helluva fuel! Bet it's not cheap.I will say the octane you have is more than enough to hold that Map
ECU psi is independent of anything JB has control of. Boost and Boost2 are charge boost and intake boost, most of the time they are near identical. They are reading a total of the ECU psi plus the target PSI set by the JB. 16-17 is a bit low, only because the ECU psi is low. Map3 is 6 psi over stock so on average you should be touching 18-19 psi on a good day. Again I don't think it's a huge issue and most likely due to cold temps. Remember, cold air is dense, therefore the car has to mix more fuel to get the proper ratio. More air and fuel is a replacement for boost to reach the same potential.@AWDGT2 wouldn’t the ecu psi always read stock values if u look at the log under boost 2 column I see as high as 16 17 psi
