Map 3 Log Check (Roughly 100 Octane from Boostane)
Calebg197
Hello all!
Hoping I can get some additional eyes on my recent log on Map 3. I am currently located in Hawaii so the best fuel we can get is 92 Octane. Race fuel and ethanol are here but not feasible to run frequently due to exceptionally high cost ($30+ per gallon). As a result I bought some Boostane to test out and did some hard pulls. Please take a look and let me know what y'all think. BMS WMI is getting ordered next month, but if Boostane looks safe I'd like to run a bit of it with my WMI just to ensure further safety from detonation (if needed, not sure if anyone runs pump gas/meth without issue).
(I know a lot of people are against Boostane, you don't have to tell me that it turns things orange lol)
Looks good.
Good to go. Boostane is doing its job.
Thank you gents!
I'm still learning so would love any advice on what else to check (or corrections to what is below)
THROTTLE - no drops from 100% after normal initial wot delay (check)
FP_H - does not drop below 10 and is fairly steady (check)
IGN_1 - decent values that increase as rpms do (check)
TRIMS - are below 49, they do get pretty high in 2nd gear (45) but do not max out, then settle down (check)
AFR - nice and steady about where target should be (check)
AFR2 - tracks well to AFR (check)
IGN_2-6 - all stay at zero indicating no knock noticed by ECU (check)
BOOST2 - tracks well with BOOST (check)
TRIMS2 - tracks close to TRIMS, no higher than 45 (check)
To me it looks great.
