map 2 log check
what gas are you running? 91 octane? timing looks a little rough. if you can keep ign 2-6 under 1.5 you are running good.
Do you have one step colder plugs properly gapped at .022?
I have the hks plugs gapped between .022 and .024 on 93 octane
keep filling up with name brand gas, Exxon, Shell, etc. and see if the timing numbers improve over the next few tanks. Or do the ECU reset and a new fresh tank of gas and log it again after a day or two.
Got it, thank you. I do primarily only fill my car with Mobil, as I get a free tank of 93 every week at my job. What’s the ECU reset?
I have bms intakes, ark mids, and a borla exhaust as well
To reset your ECU disconnect the negative battery cable for 5 minutes or so. Do this after you put some quality fuel in then do a couple more pulls, through 3rd and into 4th would be nice.
