Ok, sorry about that, ill change the settings and grab a new log. Thanks for the heads up.This log is unusable. Absolutely no WOT. Set up logging to record at 90%
Here are two pulls i just grabbed real quick, set the logging to auto at 90%.You have to travel several gears at wide open throttle. Cruising around shows very little. Also, that log was huge. Keep them to one to three good pulls and we can go from there.
The plugs were pre gapped from khartunerz, i can check the gapping on them but i believe it was .22. Im also running the fuel wires, yes. Im using 91 octane with boostane added, should i try adding a bit more and running some more logs you think after updating?It's better, only 3rd gear but enough. I see larger than normal variance between ign timing 2-6. This is an indication of not enough octane. Other things can cause it too..
What gap are the plugs?
Do you have fuel wires?
Your also running old firmware, 16? Update to at least 19 or even 22.
This is the best i could get, 2 pulls 1-3/4 had to go back and run it again because i ran out of road lol.I'd lke to see a pull from 1-4 gear with newer firmware first V22. Floor it, WOT
Awesome, thanks for your time and the peace of mind. Ill try adding a little more octane next time and see if it effects the timing. Ill keep an eye on everything!The new firmware skews the Ign2-6 and presents it a bit different than the older firmware but everything looks OK, no issues. If it was my car, I would run it as long as you add that octane.
