Map 2 log check please
Jjoeyd92
Hey everybody I’m very new to the stinger community and jb4 I would love to get some input on my log and tell me if it looks all good, I have a 2023 stinger 3.3 with the following mods
The 450 hp kit with the ngk plugs gapped at .22
Just put the ewg plugs on
It’s on map 2 with e30 mix with 93
And the mbrp active exhaust
Ark mid pipes on the way.
Just wanted to say thanks to everybody in advance and hopefully the attachment is correct, if I do anything wrong please let me know so I can fix it. Thanks again!
Ideally you want to see ign 2-6 showing less than 2.3 across the board. You're pretty much there. The car may just need to get used to it for a bit. Sounds like you did all the right stuff. if it's running smooth and pulling hard, it's all good. just check logs periodically. Use good quality gas and keep your e30 mix controlled.
If things don't continue to look good, then you can always do a ECU reset by pulling the negative battery cable off for 15 minutes. This may help clean it up too.
I just wanted to say thank you very much! I’ve been trying to do all the best things I’ve read about for the car, for drivability and getting as much horsepower as I can safely, I’m just learning with reading the logs so I really appreciate all your input and taking the time to help me.
