map 2 log check (mobil fuel)
Zillakami
posting new logs, last logs (my first) timing was a lil off, so been using consistently mobil 93, hope to see an improvement
From what I know, looks like quite a bit of timing correction.. are you using stock plugs??
That's more than a little off.
I didn't see your first but I hope it wasn't worst than this. There is no reason why timing should be this bad in just map2 other than extremely poor gas, or plugs. Were these Amazon plugs?
Plugs are from Khar, gas was 93 from Mobil, is there any danger to the car like this? I’ll run on map 0 until I can get a few tanks of shell 93 and re test
So ugly. Maybe reset the ecu?
Right away. But if the corrections are really true, they will come back.
