DekCan
- May 4, 2020
- Location
- This will allow people to see y
Ooops forgot to state. I'm on Shell E93 with BMS Intake and intercooler, JB4, Regapped Denso spark plugs, Eibach front and rear swaybars, MBRP cat back exhaust,What fuel you on? Any mods?
Yep want to see if everything is good before mixing fuel.I’m not an expert. But what I would say is, you want to hear comments from one of them.
Yes, I gapped them myself to .22. Shell 93 is the best I can get here with E30 from a cheap gas station. Will def stay on Map 2 for the time being.1st one was way better than the second. Timing was moving quite a bit on the second log. If you get a similar result on your next log, stay at map 2 until your fuel is better. Also, do you have a confirmation on plug gap?
If it's a blended pump with E30 (93 octane) that's what I would be running. No point in wasting your money for nothing. IMO. Best my car has ran was map 3 running the (cheap) gas station fuel.Yes, I gapped them myself to .22. Shell 93 is the best I can get here with E30 from a cheap gas station. Will def stay on Map 2 for the time being.
Or find E85 and blend. No Chevron 94 in your area. Not that it’s a great fuel but should be a bit better than 91.So, being that I only have access to 91 where I live... I should only ever use Map1?
Is it 91 no E? Or 91 containing up to 10% E? Only way to know if you're good for map to is to post a map 1 log then evaluate. Then try map 2.So, being that I only have access to 91 where I live... I should only ever use Map1?
My mistake I use e93 and only have e85 at a cheap gas station.If it's a blended pump with E30 (93 octane) that's what I would be running. No point in wasting your money for nothing. IMO. Best my car has ran was map 3 running the (cheap) gas station fuel.
I guess I misread. That is what you are running. You have station's that sell E-30 but not E-85?
I think it says up to 10%E if I recall... Shell 91. I don't have a JB4 at the moment, just making plans and trying to understand the maps better. I'm not planning anything much past using Map2, if I can safely.
