I haven't, I got my jb4 and plugs from a user here. They were gapped to recommended, but I don't recall the exact number. God I don't wanna take those out again lol ill try resetting the ecu. Mine Breitling explaining what I'm looking for on the log?
So found an e-85 station today, only had a few gallons left in the tank so I added 3.5 gal of e-85 and the rest 91 and made a few more pulls for logs. Not sure why it lumped all of them into one log. 1 pull in map 1 and 2 in map 2. Timings look to be a little higher? What numbers should I be looking to stay under on the ignition timing? And should I start troubleshooting with the plugs?
Not good. Try to reset your ECU by disconnecting negative battery terminal for 5 minutes. This will help it adjust to the new fuel. Then try try again. Cheers.
Logged again today after resetting the ecu. As you'll notice, I let up pretty quick after I saw some pretty high ign numbers. It looks like this log is strictly ign 1? Ign 2-6 sit suspiciously at 0.8
Yeah, that's right. So I should only be looking at 2-6 for retards or advances? May try to get a map 2 log on the way home. Everything looks safe though, yeah?
