Which fuse did you tap into for powering the ECS10I have this message that reads ''module is diabled. activate the module for use".
How is that done & how do make it so it will turn on every time I start the car.
I didn't do the install. Can u pls. tell me what fuse would work. I have someone I can check. Thanks. Rich P.S. Thanx 4/responding.Which fuse did you tap into for powering the ECS10
It very much matters. In order for the ECS10 to work correctly and reliably connect to the vehicle every time you start it, it must not be powered with constant power.I don't know what fuse. I didn't do the install. It has to be whatever fuse is there. Maybe you know which one it is?
