upsidedown
Before I go to KIA I wanted to do some testing of my own
Background:
My car was sideswiped with the back rear wheel copping most of the hit. After a wheel align the car was fine until about a week or so later it started to exhibit the diff binding on tight turns. This was when the twitchy rear end became very noticeable (as others on this forum have said when they had diff binding). The TSB was then done to add the new friction modified oil which fixed the binding
but
The car now seems to be more twitchy (but better than before the diff oil was changed) at the rear than what I remember it was before all this started. So I thought I would do some Googling and check out how to test the LSD
Testing:
1. Jack up the rear on both sides of the car
2. Put in neutral and handbrake off
3. Rotate one rear tyre and check rotation of other side. It went the same way indicating a LSD
but
I noticed that if I spun the wheel fairly quickly the other side would rotate slower and not keep up
4. Lowered one side back to the ground to check the breakaway torque. From what I had read a torque wrench
needed to be used to check the torque needed to rotate one wheel against the other that was on the ground
to find out what the clutch pack disengaged at
but
I could rotate the wheel by hand with hardly any effort required
So now I'm confused. It looks like I have a LSD but with no real clutch pack tension
Is my testing method correct? Should it be in neutral or park?
Have I determined the correct outcome?
Opinions please
Background:
but
Testing:
but
but
Opinions please
