Lowering Springs!
EClapp3
Is anyone running a 245/40-19 or any other 26.7" tall tire and on Eibach lowering springs? AWD preferably. I put new wheels on and it needs more low now. Curious if ill have any problems since it is a bit taller than stock.
That tire height shouldn't cause any issues. main concern is if you changed to lower offsets and have some poke you might have some rubbing issues.
And thats where tire height comes into play. Taller than stock tire might rub where a stock wont.
Not really when you consider suspension travel. What wheel size and offset are you running?
Again, suspension travel into the fender with a taller tire is what I'm asking about.
Why are you actively dodging my question. Fitment hinges on knowing all the dimensions you're working with, not just tire diameter. also you're talking about a mere 0.35" of height difference, the issue is where your tire is sitting inside of the wheel well.
So I ask again, what is your offset and wheel width?
You already know I have enough poke for this to be an issue or I wouldn't be asking. It doesn't matter how much poke. And its actually .7" taller than stock, which from pictures looks like it would be an issue.
If it cant fit behind the fender lip you're going to have an issue regardless if it was 26 or 26.7. fyi i have the same tire height as you.
