Hi all,
Cant find any answers to this problem I'm having.
Sorry for the long winded post just want to provide as much info to inform anyone who may have ideas. Videos at the bottom hope they work 1st time uploading to YouTube.
In our Vancouver group there are 3 of us having the same problem. I have not tested all combinations in which it will happen at this stage but here are a few conditions I have found it under so far.
• With or without launch control
• in sport or comfort mode
• from a stand still or under 2k rpm
• 1st or 2nd gear tested only at this stage.
• Automatic or using shifters
• 1 guy is completely stock 2018 GT2 and a 2019 GT2 with an AEM intake (this guys issue started before he installed the AEM intake)
• I have Borla and AEM intakes (recirc hose removed and intakes capped) 2019 GT2. We are all AWD as that's all we can get in Canada.
• 2018 has 47,000 km 2nd car 2019 32,000 km and mine is 21,000km.
• No codes are thrown.
• Only happens if tank is under half way.
Once in full acceleration from a stand still or slow crawl like idle speeds, using the conditions above the car will go limp between 4k & 6k rpm. More often it's around 4k rpm but a couple of times it happened at 6k rpm, just can't recall what I did differently for it to be at 6k rpm, possible starting at a slightly higher rpm. It holds that rpm until you let off the gas which it will change gear and resume driving. 2 of the guys have taken it in to 3 different dealerships and the techs don't know what the problem is as no codes are thrown. The 2018 had been in the shop for a week while they did diagnostics and they could not figure it out and called it a day. Closing his ticket with nothing wrong stated.
My wife took my car in and they said they could not replicate my problems. I sent them a spiel of the problem with 2 videos showing the issue. I made them take my wife out so she could show them the problem. They are now aware of the issue. Of course they say, well you have an after market exhaust and air intakes and that requires a tune. Which it doesnt.
Anyway they want to take it for 7 days, run some test to see what's up. I know they are going to come up blank as they did it the guys 2018 after 7 days of testing. There is no such thing as a mechanic in these places. No problem solvers. A bunch of tards that need a code to fix something.
Just weird at over 1/2 a tank no problems. As soon as its 1mm under the 1/2 way mark it starts playing up.
Appreciate your time guys and any ideas I can try.
