Snowwhite
Sustaining Member
- Feb 3, 2020
Has anyone installed longer rear studs on the rear axle? I want to add some 10mm spacers and definitely need the longer studs. stock without spacer had 10 turns for each lug nut, 10mm spacers only gave me 5 turns.
the service manual says to remove pretty much the entire rear spindle assembly to get to the hub from the rear, but no mention of replacement of studs, which hopefully would have a shorter method. Anyone try it?
I've researched on youtube, google, etc. and havent' found anything G70/Stinger specific.
thanks!
thanks!
