Logs Post and JB4 Connection Issue
magictuli
Posting my logs (only 2, just installed JB4) for insight and maybe an idea of what I could do with the custom Map6 option. I also have an issue with my JB4 disconnecting when I try to take logs. So far, after maybe 10-15 minutes of log taking, the JB4 disconnects and won’t reconnect until I turn off the car completely then back on. All I have installed are the HKS plugs gapped to .22. I have injen cold intake and a HKS BOV coming in soon too.
Logs are a WOT run from 40 to 90 what you posted is just driving around crap. Set your JB4 to auto log at 80% throttle. Do a WOT run and repost.
I don't think it needs to be 40-90 specifically (hard to do in many places)...20 to 70 or 80 should be fine, just WOT through at least a couple of gears. Agree to just use the default auto log, so you aren't fiddling with the app and filling logs with hundreds of rows of irrelevant low-throttle info.
BMS who makes the thing recommends 40-90. I‘m sure a WOT shot from 3rd thru 4th would suffice. Either way going WOT gets the speed up real fast so one needs to be careful.
Thanks for the help. Unfortunately, I live in Hawaii and there isn’t much open road to get that on but I’ll definitely try and do the auto log stuff.
