Log Check Please
Mudpupy
Roanoke, VA.
Hello new to this turbo tuning game. Installed my JB4 and new plugs gapped to .022 yesterday.
Plugs were challenging but got through it okay. JB4 was very simple to understand and connect.
Thank you Terry for a fantastic product. I've attached a couple logs and would appreciate someone
looking over them for me. Car felt like it was running fine with no codes set. Conditions, 62 degrees
and sunny, 93 octane and Map 2 setting. K&N CAI, MBRP Cat back exhaust. Thanks in advance Art
It's been a couple years since I ran logs myself but your IGN 2 thru 6 look like you don't have the setting turned on to record the ignition advance in all cylinders. Turning this function on allows you to see if you have any particular cylinders not running full ignition advance and see if any are not ideal.
Boost looks healthy and IGN 1 looks good though.
Thank you
Are you using the mobile app? If so how did you turn on logging for all ignitions? Mine also only logging ign 1
Yes I am, I read somewhere that the new JB4 only logs ign 1
and only references 2-6.
I reached out to them today regarding it and if u go to user adjustment and change user a bit - 1 then it will log all 6
