Log check, please!
Ahawk1968
El Paso
Hi folks, had been messing around with e85 mixtures.. 4.5 gallons to full tank of 91. Any thoughts on these logs? Only difference was pulling a few pounds of boost via boost by gear on the second log. Did help the zero to 60 but strangely felt slower.. thanks!
Seems OK to me
Terry, do you think map 3 with the current e85 mix is advisable? Also, is it accurate to judge wheelspin by looking at the throttle value in the Excel spreadsheet... If the ECU is limiting throttle then that would be indicative of spin? Thanks for the help.
You judge wheel spin be looking at the slope of RPM.
Update to v13 firmware and grab a map3 log and lets see!
Thanks for the info, much appreciated! Y'all are quick... I though I had the latest with v12!
