Log check please and thanks (first one!)
StingerJefferson
Today was the first day I was able to really lean into the car with the JB4, exhaust and scoops. I stuck with map 1 cause I'm taking it slow.
I've got 5 files attached here. I have logging set combine files in 2 hour increments, so I'm not sure why it produced 5 files; it would also stop logging every 15-20 minutes and the dials on the iPhone would go dead until I hit "start logging" again.
I'll dig into that later today, just wanted to provide the explanation.
Thank you in advance!
By pressing "start logging" you were manually recording logs, most of which are useless. Let it start/stop logging on it's own using the auto logging feature.
[FACEPALM]
Got it, will do. Thank you, Terry.
It was a fun drive, at least.
Ok! I think I 1) configured the app correctly this time and 2) got several good runs at WOT, usually up to 60-70mph.
I'm going to try and take a look, too, based on what I've read in other posts, but I would really appreciate a review by someone who truly knows what they're doing.
Thank you!
You want to log through fourth gear, letting it shift into fifth for a few seconds, ideally.
So I still did it wrong? That’s frustrating.
I do appreciate the direction tho.
2nd gear or 3rd gear at 2-3k rpms. 100% throttle all the way.
Runs seems fine to me for map1.
Thanks, all!
I appreciate the feedback. I'll know to hold it open longer when I next have a chance to run and give map 2 a try.
Thanks for taking a look!
