Limp Mode
StingNTow
Hey guys got a 2022 Scorpion, having some issues when I been racing people or doing hard launches, Im Not sure why But all of a sudden my car will only build 2 pounds of boost, but still completely pull hard N/A and when i shut the car off and back on its fine again and builds boost, does any1 know what limp mode I could be getting and whats causing it?
MODS: Jun-Bl secondaires/ Borla catback / Injen Intakes with Hydro shields / HKS Twin BOVs
No tune or piggy back
overboosting when the car is still cold. common for the 22s
I was hot and idiling 10mins before we raced
it takes more then 10 minutes for the car to be hot if you are just idle, also, ALL of your mods only increase airflow (as well as give you no performance boosts at all without a tune) which are know to cause the 22's to misbehave because they have slightly different turbos than previous years. There are accounts of bone stock cars on here doing this, let alone yours.
Word so i got the jb4 and pluge and the ewg wires and pre tapped fuel wires hoping to solve this issue
Do you have a guesstimate of what it will be with my mods and the ib4 on shell 93 nitro(all i put in it)
map 2 on the Jb4 should put you around 400AWHP if you are AWD, 410/415 RWHP if you are RWD, up from the 310/330WHP that the car has stock depending on the drivetrain.
AWD Scorpions only come that way I believe
Did it solve the issue
Have a 2021 gt1 and they were not right about a jb4 resolving this, it may be related to engine Temps but I havent pinned that down, to me it seems the engine senses overboost and cuts the psi
