Kia Stinger DT-P Coilovers (Fits 2.0T and 3.3T)
TEAM ARK
Ontario, California
  • Fits 2018-On Kia Stinger 2.0T and 3.3T
  • Front Spring Rate: 7 kg/mm
  • Rear Spring Rate: 10 kg/mm
  • Dampening Adjustment 16 Levels to customize to your driving style.
  • Pillow Ball Mounts create a more precise feel and handling.
  • Monotube Shock Design that reacts quickly for immediate response.
  • DLC (Diamond Like Carbon) Coated Shaft for long term durability and the ideal friction coefficient.
  • Optional ECS (Electronically Controlled Suspension) Code Canceler to prevent unwanted warning lights from popping up.
Interesting that the same spring rate is specified for 2.0L and 3.3L options, given there must be some weight difference between the two!
These will make it on my car next year
We're more focus on 3.3T spec engine on coilover system. It does fit 2.0t Sitnger and you can always able customize spring rate anytime.
@TEAM ARK What are the shock bodies made from; Steel, Aluminum, Stainless?
Do you have a camber and Caster kit (front and/or back) for the stinger gt?
