Kia Stinger 2018 Base Spark Plug Location
4 cylinders, 4 spark plugs. I can't imagine they'd take much more than just lifting the engine cover, coil packs should be there, pull those and plugs should be there. I haven't seen an inline-4 that was more complicated than that.
But the GT has 6 cylinders and it comes with 4 plugs. The base model is the same?
...What? The GT certainly has 6 plugs. You'll never see modern gasoline car engine with fewer plugs than cylinders. The V6 in the GT has 6, the straight 4 in the 2.0T..has 4.
Ok. I found one of them. Couldn’t find the rest.
